Introducción
This guide will show how to replace the camera lens on a Sony Cyber-Shot DSC-W80.
Partes
No se requieren partes.
  1. Open the battery cover by sliding it towards you. Open the battery cover by sliding it towards you.
    • Open the battery cover by sliding it towards you.
  2. Push the purple latch with your thumb to unlock the battery.
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the eight Phillips #000 screws. Remove the eight Phillips #000 screws. Remove the eight Phillips #000 screws.
    • Remove the eight Phillips #000 screws.
  5. Remove the single Phillips #000 screw found next to the battery latch.
    • Remove the single Phillips #000 screw found next to the battery latch.
  6. Remove the middle panel on the side of the device. Slowly pry the camera apart at its seem.
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  7. Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors. Once disconnected, use your fingers to lift lens out of the frame. Once disconnected, use your fingers to lift lens out of the frame.
    • Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Once disconnected, use your fingers to lift lens out of the frame.
Conclusión
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 58
