Saltar al contenido principal
Sony Cybershot DSC-W80 LCD Screen Replacement
Qué necesitas
  1. Sony Cybershot DSC-W80 LCD Screen Replacement, Battery: paso 1, imagen 1 de 2 Sony Cybershot DSC-W80 LCD Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Open the battery cover by sliding it towards you.
  2. Sony Cybershot DSC-W80 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Sony Cybershot DSC-W80 LCD Screen Replacement, Front/Back Panels: paso 3, imagen 1 de 3 Sony Cybershot DSC-W80 LCD Screen Replacement, Front/Back Panels: paso 3, imagen 2 de 3 Sony Cybershot DSC-W80 LCD Screen Replacement, Front/Back Panels: paso 3, imagen 3 de 3
    • Remove the eight Phillips #000 screws.
  4. Sony Cybershot DSC-W80 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Remove the single Phillips #000 screw found next to the battery latch.
  5. Sony Cybershot DSC-W80 LCD Screen Replacement: paso 5, imagen 1 de 2 Sony Cybershot DSC-W80 LCD Screen Replacement: paso 5, imagen 2 de 2
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  6. Sony Cybershot DSC-W80 LCD Screen Replacement, LCD Screen: paso 6, imagen 1 de 3 Sony Cybershot DSC-W80 LCD Screen Replacement, LCD Screen: paso 6, imagen 2 de 3 Sony Cybershot DSC-W80 LCD Screen Replacement, LCD Screen: paso 6, imagen 3 de 3
    • Lift the power button board up off of the daughterboard.
  7. Sony Cybershot DSC-W80 LCD Screen Replacement: paso 7, imagen 1 de 1
    • Remove the single Phillips #000 screw.
    • Use your hands to remove the blue daughterboard.
  8. Sony Cybershot DSC-W80 LCD Screen Replacement: paso 8, imagen 1 de 2 Sony Cybershot DSC-W80 LCD Screen Replacement: paso 8, imagen 2 de 2
    • Flip the camera around.
    • Remove the black and orange ribbon cables.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 26
Todo El Tiempo: 523
