Saltar al contenido principal
Sony Cyber-shot DSC-WX80 Battery Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: paso 1, imagen 1 de 3 Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: paso 1, imagen 2 de 3 Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Begin by removing all six #00 screws holding the outer chassis together with the Phillips #00 Precision Screwdriver.
    • Remember to keep track of all screws as they are small and very easy to lose
  2. Sony Cyber-shot DSC-WX80 Battery Replacement: paso 2, imagen 1 de 3 Sony Cyber-shot DSC-WX80 Battery Replacement: paso 2, imagen 2 de 3 Sony Cyber-shot DSC-WX80 Battery Replacement: paso 2, imagen 3 de 3
    • Take note of the small free moving flap near the battery port seen in the first of the three photos. Be sure to store the free moving flap in a safe place.
    • Pry the front cover off gently. Use a plastic opening tool if available.
    • Now pry the back cover off gently, using a plastic opening tool if available.
  3. Sony Cyber-shot DSC-WX80 Battery Replacement: paso 3, imagen 1 de 1
    • Access where the replacement battery will go indicated by the red square in the photo to your left
    • Now insert your new replacement battery
Conclusión
2 comentarios
Why did you not just open the bottom battery door instead of pulling the camera apart?
Kat - Contestar
I am also suprised to know that I should dis-assemble to replace battery. It maybe a joke.
Chung-Suh Ku - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 19
Todo El Tiempo: 1,039
