Saltar al contenido principal
Sony Cyber-shot DSC-WX350 Flash Assembly Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: paso 1, imagen 1 de 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: paso 1, imagen 2 de 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: paso 1, imagen 3 de 3
    • Remove 6 black Phillips 4 mm screws using the J00 head screwdriver tip from the sides and bottom of top cover.
  2. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 2, imagen 1 de 1
    • Remove the black Phillips 4 mm screw using the J00 head screwdriver tip from inside the battery inclosure.
  3. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 3, imagen 1 de 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to take back cover off. Then take out the LCD screen with your hand.
  4. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 4, imagen 1 de 1
    • Now take the control wheel board out with your hand.
  5. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 5, imagen 1 de 1
    • On the left side of the camera, pull the LCD off the back plate.
    • There will be a ZIF connector by the control wheel, release the connector and remove the LCD.
  6. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 6, imagen 1 de 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 6, imagen 2 de 2
    • Remove silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal cover. Once done take the metal cover off with your hands.
  7. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 7, imagen 1 de 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 7, imagen 2 de 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 7, imagen 3 de 3
    • Using your finger open take off the three zifs.
  8. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 8, imagen 1 de 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 8, imagen 2 de 2
    • Use your hand to take out the lens assembly. Then take out the motherboard assembly with your hand.
  9. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 9, imagen 1 de 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 9, imagen 2 de 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 9, imagen 3 de 3
    • Remove the silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal piece and remove the 4mm screws from the metal piece lining the lens assembly hole.
  10. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 10, imagen 1 de 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: paso 10, imagen 2 de 2
    • Grab the top of the camera and take it out. Then grab the flash assembly and slide it out.
Conclusión
4 personas más completaron esta guía.
Equipo
IUPUI, Team S1-G1, Wilson Summer 2017 Miembro de IUPUI, Team S1-G1, Wilson Summer 2017
IUPUI-WILSON-SU17S1G1
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 1,637
