Saltar al contenido principal
Sony Cyber-shot DSC-WX220 Lens Assembly Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the gray switch from lock to open position.
  2. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: paso 2, imagen 1 de 2 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: paso 2, imagen 2 de 2
    • Pull down on the blue tab to release the battery.
  3. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Outer Case: paso 3, imagen 1 de 3 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Outer Case: paso 3, imagen 2 de 3 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Outer Case: paso 3, imagen 3 de 3
    • Use a PH00 screwdriver to remove the five 3.5 mm screws.
    • Use a PH00 screwdriver to remove the two 2.5 mm screws.
  4. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: paso 4, imagen 2 de 2
    • Pry apart the case gently using a plastic opening tool.
  5. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Lens Assembly: paso 5, imagen 1 de 1
    • Pry back the panel to the right of the screen using a plastic opening tool.
  6. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: paso 6, imagen 1 de 1
    • Working on the left side of the screen, pry the metal panel off from the motherboard housing using a plastic opening tool.
  7. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: paso 7, imagen 1 de 1
    • Pull out the ZIF cable from the motherboard.
    • When removing the ZIF cable, pull it straight out to avoid damaging the cable.
  8. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: paso 8, imagen 1 de 2 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: paso 8, imagen 2 de 2
    • Unpin the ZIF cable by lifting the cable towards the top of the camera while pulling up towards yourself.
    • Pull the ZIF cable out.
  9. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: paso 9, imagen 1 de 1
    • Lift the lens out of the case.
    • Pull out the ZIF cable.
Conclusión
2 personas más completaron esta guía.
Kate Glazer
Miembro Desde 03/20/18
621 Reputación
5 Guías creadas
Equipo
IUPUI, Team S6-G3, Baechle Spring 2018 Miembro de IUPUI, Team S6-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G3
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 1,065
