Saltar al contenido principal
Sony Cyber-shot DSC-WX220 Flash Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-WX220 Flash Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the gray switch from lock to open position.
  2. Sony Cyber-shot DSC-WX220 Flash Replacement: paso 2, imagen 1 de 2 Sony Cyber-shot DSC-WX220 Flash Replacement: paso 2, imagen 2 de 2
    • Pull down on the blue tab to release the battery.
  3. Sony Cyber-shot DSC-WX220 Flash Replacement, Outer Case: paso 3, imagen 1 de 3 Sony Cyber-shot DSC-WX220 Flash Replacement, Outer Case: paso 3, imagen 2 de 3 Sony Cyber-shot DSC-WX220 Flash Replacement, Outer Case: paso 3, imagen 3 de 3
    • Use a PH00 screwdriver to remove the five 3.5 mm screws.
    • Use a PH00 screwdriver to remove the two 2.5 mm screws.
  4. Sony Cyber-shot DSC-WX220 Flash Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-WX220 Flash Replacement: paso 4, imagen 2 de 2
    • Pry apart the case gently using a plastic opening tool.
  5. Sony Cyber-shot DSC-WX220 Flash Replacement, Flash Assembly: paso 5, imagen 1 de 1
    • Pry back the panel to the right of the screen using a plastic opening tool.
  6. Sony Cyber-shot DSC-WX220 Flash Replacement: paso 6, imagen 1 de 1
    • Working on the left side of the screen, pry the metal panel off from the motherboard housing using a plastic opening tool.
  7. Sony Cyber-shot DSC-WX220 Flash Replacement: paso 7, imagen 1 de 1
    • Pull out the ZIF cable from the motherboard.
    • When removing the ZF cable, pull it straight out to avoid damaging the cable.
  8. Sony Cyber-shot DSC-WX220 Flash Replacement: paso 8, imagen 1 de 1
    • Pull the capacitor out of the shell.
    • Be careful not to shock yourself on the capacitor(metal components on the top)
  9. Sony Cyber-shot DSC-WX220 Flash Replacement: paso 9, imagen 1 de 1
    • Unpin the flash assembly.
  10. Sony Cyber-shot DSC-WX220 Flash Replacement: paso 10, imagen 1 de 1
    • Lift flash component toward you and gently pull the ZIF cable up and away from the camera.
Conclusión
Kate Glazer
Miembro Desde 03/20/18
621 Reputación
5 Guías creadas
Equipo
IUPUI, Team S6-G3, Baechle Spring 2018 Miembro de IUPUI, Team S6-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G3
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 15
Todo El Tiempo: 559
