Saltar al contenido principal
Sony Cyber-shot DSC-WX100 Battery Replacement
  1. Sony Cyber-shot DSC-WX100 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Battery Replacement: paso 2, imagen 1 de 1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
Conclusión
Una persona más ha completado esta guía.
Peter Prins
Miembro Desde 03/19/15
262 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,029
