Saltar al contenido principal
Sony Cyber-shot DSC-W800 Lens Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: paso 1, imagen 1 de 3 Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: paso 1, imagen 2 de 3 Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: paso 1, imagen 3 de 3
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 Lens Replacement: paso 2, imagen 1 de 2 Sony Cyber-shot DSC-W800 Lens Replacement: paso 2, imagen 2 de 2
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 Lens Replacement: paso 3, imagen 1 de 3 Sony Cyber-shot DSC-W800 Lens Replacement: paso 3, imagen 2 de 3 Sony Cyber-shot DSC-W800 Lens Replacement: paso 3, imagen 3 de 3
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
  4. Sony Cyber-shot DSC-W800 Lens Replacement, LCD Screen: paso 4, imagen 1 de 1
    • Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
  5. Sony Cyber-shot DSC-W800 Lens Replacement: paso 5, imagen 1 de 1
    • Lift the back panel and separate the LCD Screen by prying it up.
    • Remove the back panel.
  6. Sony Cyber-shot DSC-W800 Lens Replacement: paso 6, imagen 1 de 2 Sony Cyber-shot DSC-W800 Lens Replacement: paso 6, imagen 2 de 2
    • Gently pull on the ribbon wire disconnecting from the ZIF connector (connecting the LCD screen to the motherboard) with the tweezers.
    • Ribbon wires can be easily damaged.
  7. Sony Cyber-shot DSC-W800 Lens Replacement, Lens: paso 7, imagen 1 de 2 Sony Cyber-shot DSC-W800 Lens Replacement, Lens: paso 7, imagen 2 de 2
    • With plastic opening tool, gently pry loose the front panel.
    • Separate front panel from the camera housing.
  8. Sony Cyber-shot DSC-W800 Lens Replacement: paso 8, imagen 1 de 3 Sony Cyber-shot DSC-W800 Lens Replacement: paso 8, imagen 2 de 3 Sony Cyber-shot DSC-W800 Lens Replacement: paso 8, imagen 3 de 3
    • Remove the lens housing by pushing it, from the front, through the housing and lifting it out.
    • Gently pull on the large ribbon wire (connecting the Lens housing to the motherboard via ZIF connector) with the tweezers.
    • Gently pull on the small ribbon wire (connecting the Lens housing to the motherboard) with the tweezers.
    • Be careful not to damage either of the ribbon wires.
Conclusión
3 personas más completaron esta guía.
Thomas Campo
Miembro Desde 02/09/16
788 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 17-5, Blackwell Winter 2016 Miembro de USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 18
Ultimos 30 días: 45
Todo El Tiempo: 4,317
