Saltar al contenido principal
Sony Cyber-shot DSC-W800 Button Board Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: paso 1, imagen 1 de 3 Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: paso 1, imagen 2 de 3 Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: paso 1, imagen 3 de 3
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 Button Board Replacement: paso 2, imagen 1 de 2 Sony Cyber-shot DSC-W800 Button Board Replacement: paso 2, imagen 2 de 2
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 Button Board Replacement: paso 3, imagen 1 de 3 Sony Cyber-shot DSC-W800 Button Board Replacement: paso 3, imagen 2 de 3 Sony Cyber-shot DSC-W800 Button Board Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
Conclusión
3 personas más completaron esta guía.
Thomas Campo
Miembro Desde 02/09/16
809 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 17-5, Blackwell Winter 2016 Miembro de USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
5 Miembros
5 Guías creadas
4 comentarios
Thanks for this - was spot on and allowed me to easily fix the problem I was experiencing!
jimbradshaw - Contestar
follow the step camera button loosen a bit unstuck but camera still stock on language setting and do not budge
Trisha Amable Girlfridayz - Contestar
follow the step the button are unstuck but the camera display still stock on language setting
i need a new strip, because old strip was damaged.
moonbhaai@gmail.com
Naveed Shoukat - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 38
Todo El Tiempo: 2,456
