Saltar al contenido principal
Sony Cyber-shot DSC-W730 Outer Case Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-W730 Outer Case Replacement, Removing the Case: paso 1, imagen 1 de 3 Sony Cyber-shot DSC-W730 Outer Case Replacement, Removing the Case: paso 1, imagen 2 de 3 Sony Cyber-shot DSC-W730 Outer Case Replacement, Removing the Case: paso 1, imagen 3 de 3
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Sony Cyber-shot DSC-W730 Outer Case Replacement: paso 2, imagen 1 de 3 Sony Cyber-shot DSC-W730 Outer Case Replacement: paso 2, imagen 2 de 3 Sony Cyber-shot DSC-W730 Outer Case Replacement: paso 2, imagen 3 de 3
    • Take off the front part of the case with a plastic opening tool.
  3. Sony Cyber-shot DSC-W730 Outer Case Replacement: paso 3, imagen 1 de 2 Sony Cyber-shot DSC-W730 Outer Case Replacement: paso 3, imagen 2 de 2
    • Pull off the two silver side pieces on the left and right sides.
  4. Sony Cyber-shot DSC-W730 Outer Case Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-W730 Outer Case Replacement: paso 4, imagen 2 de 2
    • Remove the main back piece. It should easily lift off.
  5. Sony Cyber-shot DSC-W730 Outer Case Replacement: paso 5, imagen 1 de 3 Sony Cyber-shot DSC-W730 Outer Case Replacement: paso 5, imagen 2 de 3 Sony Cyber-shot DSC-W730 Outer Case Replacement: paso 5, imagen 3 de 3
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team 9-4, Blackwell Winter 2015 Miembro de USF Tampa, Team 9-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G4
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 761
