Introducción
This could be a solution to the buttons on the back of the camera not working. This is an easy replacement. Just be careful with the ribbons.
Qué necesitas
Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
