Saltar al contenido principal
Sony Cyber-shot DSC-W570 Case Cover Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-W570 Case Cover Replacement, Case Cover: paso 1, imagen 1 de 1
    • Remove the two Phillips head, 2.93 mm long screws at the bottom of the camera.
    • Make sure the battery compartment door is in lock position.
  2. Sony Cyber-shot DSC-W570 Case Cover Replacement: paso 2, imagen 1 de 1
    • Turn the camera sideways so the left side is fasning upwards, remove the two Phillips head, 2.93 mm screws.
  3. Sony Cyber-shot DSC-W570 Case Cover Replacement: paso 3, imagen 1 de 1
    • Now turn the device so the opposite side is fasning upwards and remove the last two Phillips head, 2.93 mm screws.
  4. Sony Cyber-shot DSC-W570 Case Cover Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-W570 Case Cover Replacement: paso 4, imagen 2 de 2
    • To remove the front cover, use a plastic opening tool gently pry the top cover.
    • Then gently lift the cover off.
  5. Sony Cyber-shot DSC-W570 Case Cover Replacement: paso 5, imagen 1 de 2 Sony Cyber-shot DSC-W570 Case Cover Replacement: paso 5, imagen 2 de 2
    • To remove the back case cover from the body.
    • First use a plastic opening tool gently pry along the side of the camera.
    • Then slowly and gently lift the cover off.
Conclusión
Una persona más ha completado esta guía.
Zizheng Su
Miembro Desde 01/21/15
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 9-1, Brown Winter 2015 Miembro de USF Tampa, Team 9-1, Brown Winter 2015
USFT-BROWN-W15S9G1
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 740
