Introducción
We will explain the steps needed in order to replace a LCD screen.
Qué necesitas
Slide the battery cover in the direction the arrow points.
Pull the battery cover towards you.
Using the Phillips #00 screwdriver, remove the two screws from the caution panel.
Remove that panel.
Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
Herramienta utilizada en este paso:Tweezers$4.99
Flip the black secure locks off. Tweezers may be necessary.
Detach the two orange cables.
Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
Verify the orange cables from the motherboard are removed from the LCD screen.
Lift the LCD screen off the hinge.
5 personas más completaron esta guía.
