Saltar al contenido principal
Sony Cyber-shot DSC-W55 LCD Screen Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Battery: paso 1, imagen 1 de 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 2, imagen 1 de 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 2, imagen 2 de 2
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Back Case: paso 3, imagen 1 de 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement, Back Case: paso 3, imagen 2 de 2
    • Using the Phillips #00 screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 4, imagen 2 de 2
    • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
    • Remove the panel.
  5. Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 6, imagen 1 de 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 6, imagen 2 de 2
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
  7. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Front Case: paso 7, imagen 1 de 1
    • Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
  8. Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 8, imagen 1 de 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 8, imagen 2 de 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 8, imagen 3 de 3
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
  9. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Lens: paso 9, imagen 1 de 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement, Lens: paso 9, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Flip the black secure locks off. Tweezers may be necessary.
    • Detach the two orange cables.
  10. Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 10, imagen 1 de 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 10, imagen 2 de 2
    • Gently pull the lens container out of the camera.
  11. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Motherboard - First Half: paso 11, imagen 1 de 1
    • Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
  12. Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 12, imagen 1 de 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 12, imagen 2 de 2
    • Remove the two orange cables on the top of the motherboard with tweezers.
    • Lift the motherboard out of its slot.
  13. Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 13, imagen 1 de 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 13, imagen 2 de 2
    • For the AV port, detach the bottom orange cable.
    • For the LCD screen, detach the top orange cable on the right side of the motherboard.
    • For the motherboard, detach all the orange cables.
    • Careful not to damage the red, white, and black wires when lifting the board.
  14. Sony Cyber-shot DSC-W55 LCD Screen Replacement, LCD Screen: paso 14, imagen 1 de 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement, LCD Screen: paso 14, imagen 2 de 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement, LCD Screen: paso 14, imagen 3 de 3
    • Verify the orange cables from the motherboard are removed from the LCD screen.
    • Lift the LCD screen off the hinge.
  15. Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 15, imagen 1 de 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 15, imagen 2 de 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 15, imagen 3 de 3
    • Verify that the LCD screen is attached to the chip on the back on the camera.
    • Remove the dial from the back of the camera. It pops right off very easily.
    • Remove the screw using a Phillips #00 Screwdriver from the camera.
  16. Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 16, imagen 1 de 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: paso 16, imagen 2 de 2
    • Remove the orange cable that is attached between the top of the camera and the chip. It should slide straight out with a little bit of force.
    • Remove the chip and the LCD screen now from the camera.
    • The chip may need a slight upward tug with a fingernail or tweezer.
Conclusión
5 personas más completaron esta guía.
Eddie Lo
Miembro Desde 10/11/10
334 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 9-20, Regan Fall 2010 Miembro de Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
Miembros de 5
20 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 31
Todo El Tiempo: 14,639
