Introducción
Knowledge of how to remove the outer casing is necessary to replace it. (See guide)
Qué necesitas
Find the hatch labeled "open" on the left side of the bottom of the camera.
Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
Remove the four 2.5mm Phillips #0 screws.
Una persona más ha completado esta guía.
