Saltar al contenido principal
Sony Cyber-shot DSC-W290 casing Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-W290 casing Replacement, Battery: paso 1, imagen 1 de 1
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
  2. Sony Cyber-shot DSC-W290 casing Replacement: paso 2, imagen 1 de 1
    • Slide the blue locking tab to release the battery.
    • Slide the battery out of the camera.
  3. Sony Cyber-shot DSC-W290 casing Replacement, Outer Casing: paso 3, imagen 1 de 2 Sony Cyber-shot DSC-W290 casing Replacement, Outer Casing: paso 3, imagen 2 de 2
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
  4. Sony Cyber-shot DSC-W290 casing Replacement: paso 4, imagen 1 de 3 Sony Cyber-shot DSC-W290 casing Replacement: paso 4, imagen 2 de 3 Sony Cyber-shot DSC-W290 casing Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
    • Remove the two 2.5mm Phillips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
  5. Sony Cyber-shot DSC-W290 casing Replacement: paso 5, imagen 1 de 3 Sony Cyber-shot DSC-W290 casing Replacement: paso 5, imagen 2 de 3 Sony Cyber-shot DSC-W290 casing Replacement: paso 5, imagen 3 de 3
    • Turn the camera so the right side faces you.
  6. Sony Cyber-shot DSC-W290 casing Replacement: paso 6, imagen 1 de 1
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
  7. Sony Cyber-shot DSC-W290 casing Replacement: paso 7, imagen 1 de 2 Sony Cyber-shot DSC-W290 casing Replacement: paso 7, imagen 2 de 2
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
  8. Sony Cyber-shot DSC-W290 casing Replacement: paso 8, imagen 1 de 2 Sony Cyber-shot DSC-W290 casing Replacement: paso 8, imagen 2 de 2
    • Turn camera so that the front of the camera is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
  9. Sony Cyber-shot DSC-W290 casing Replacement: paso 9, imagen 1 de 2 Sony Cyber-shot DSC-W290 casing Replacement: paso 9, imagen 2 de 2
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
  10. Sony Cyber-shot DSC-W290 casing Replacement: paso 10, imagen 1 de 2 Sony Cyber-shot DSC-W290 casing Replacement: paso 10, imagen 2 de 2
    • This is what your camera should look like now that you have removed the casing from all sides.
Conclusión
Una persona más ha completado esta guía.
Evan Mayer
Miembro Desde 10/05/10
336 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 7-54, Amido Fall 2010 Miembro de Cal Poly, Team 7-54, Amido Fall 2010
CPSU-AMIDO-F10S7G54
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 15
Todo El Tiempo: 1,895
