Saltar al contenido principal
Sony Cyber-shot DSC-W150 Front Casing Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-W150 Front Casing Replacement, Back Casing: paso 1, imagen 1 de 1
    • The screws from the camera are extremely small, so it is a good idea to have a small container to hold all the screws as you remove them.
  2. Sony Cyber-shot DSC-W150 Front Casing Replacement: paso 2, imagen 1 de 1
    • Take your screwdriver and remove the four silver bottom screws of the camera.
    • The picture shows the lens facing away from you and the LCD facing you.
  3. Sony Cyber-shot DSC-W150 Front Casing Replacement: paso 3, imagen 1 de 1
    • On the right side of the camera, remove the two silver screws using the screwdriver.
    • The picture shows the lens facing away from you and the LCD screen facing you.
  4. Sony Cyber-shot DSC-W150 Front Casing Replacement: paso 4, imagen 1 de 1
    • On the left side of the camera, remove the two silver screws using the screwdriver.
  5. Sony Cyber-shot DSC-W150 Front Casing Replacement: paso 5, imagen 1 de 1
    • Gently detach the back cover by holding onto both sides of the camera and pulling them apart.
  6. Sony Cyber-shot DSC-W150 Front Casing Replacement: paso 6, imagen 1 de 1
    • After detaching the back cover, carefully pull it off.
  7. Sony Cyber-shot DSC-W150 Front Casing Replacement: paso 7, imagen 1 de 1
    • The back cover should now be separated from the camera.
  8. Sony Cyber-shot DSC-W150 Front Casing Replacement, Front Casing: paso 8, imagen 1 de 1
    • Keep track of the small screws that you remove.
    • Opening, removing, and/or replacing the front casing may void your manufacturer's warranty.
  9. Sony Cyber-shot DSC-W150 Front Casing Replacement: paso 9, imagen 1 de 1
    • Remove the two screws at the top of the camera casing.
  10. Sony Cyber-shot DSC-W150 Front Casing Replacement: paso 10, imagen 1 de 1
    • After removing the screws, gently pop open the plastic piece, as shown by firmly pulling it with your fingers.
  11. Sony Cyber-shot DSC-W150 Front Casing Replacement: paso 11, imagen 1 de 1
    • After popping open the plastic piece, there is a screw that needs to be removed.
    • Remove the screw connecting the front casing to the electrical components.
  12. Sony Cyber-shot DSC-W150 Front Casing Replacement: paso 12, imagen 1 de 1
    • On the casing on the opposite side of the camera, gently loosen and remove the casing by firmly pulling with your fingers.
    • Be cautious not to break the fragile pieces or scratch the LCD screen.
  13. Sony Cyber-shot DSC-W150 Front Casing Replacement: paso 13, imagen 1 de 1
    • Remove the two screws connecting the front casing to the electrical components using a screwdriver.
  14. Sony Cyber-shot DSC-W150 Front Casing Replacement: paso 14, imagen 1 de 1
    • Gently loosen the front casing by gently using your fingers to pull it apart.
    • Be cautious not to scratch any of the exposed electrical components.
  15. Sony Cyber-shot DSC-W150 Front Casing Replacement: paso 15, imagen 1 de 1
    • Fully remove the front casing from the camera and set it aside.
Conclusión
5 personas más completaron esta guía.
Equipo
Cal Poly, Team 33-73, Johann Spring 2010 Miembro de Cal Poly, Team 33-73, Johann Spring 2010
CPSU-JOHANN-S10S33G73
Miembros de 3
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 6,167
