Saltar al contenido principal
Sony Cyber-shot DSC-TX7 Front Cover Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-TX7 Front Cover Replacement, Battery: paso 1, imagen 1 de 2 Sony Cyber-shot DSC-TX7 Front Cover Replacement, Battery: paso 1, imagen 2 de 2
    • The battery compartment is located on the bottom of camera.
    • Move the slider from the 'lock' position to the 'open' position.
  2. Sony Cyber-shot DSC-TX7 Front Cover Replacement: paso 2, imagen 1 de 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: paso 2, imagen 2 de 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: paso 2, imagen 3 de 3
    • Battery not shown.
    • Pull battery from compartment.
    • Insert newly charged battery into compartment, as shown in diagram (located in compartment).
    • Shut compartment door.
    • Move the slider back to the 'lock' position.
  3. Sony Cyber-shot DSC-TX7 Front Cover Replacement, Front Cover: paso 3, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the 4mm length screws. There are 6 screws total.
  4. Sony Cyber-shot DSC-TX7 Front Cover Replacement: paso 4, imagen 1 de 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: paso 4, imagen 2 de 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: paso 4, imagen 3 de 3
    • The 4 mm length screws are located on each side and on the bottom of the camera.
    • 2 screws on each side (4 total).
    • 2 screws on bottom.
  5. Sony Cyber-shot DSC-TX7 Front Cover Replacement: paso 5, imagen 1 de 1
    • Gently pry around the front cover using the plastic opening tool.
    • Carefully separate front cover from body of camera.
  6. Sony Cyber-shot DSC-TX7 Front Cover Replacement: paso 6, imagen 1 de 1
    • The front cover is now removed from the camera and the internal hardware is now visible.
    • They front cover will still be connected by a ribbon. Be careful not to break the ribbon.
Conclusión
Leslie Mundell
Miembro Desde 03/18/15
411 Reputación
4 Guías creadas
Equipo
Michigan Tech, Team 1-8, Lauer Spring 2015 Miembro de Michigan Tech, Team 1-8, Lauer Spring 2015
MTU-LAUER-S15S1G8
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 14
Todo El Tiempo: 365
