Saltar al contenido principal
Sony Cyber-shot DSC-TX55 LCD Screen Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 3 Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: paso 1, imagen 2 de 3 Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: paso 1, imagen 3 de 3
    • Slide open the battery cover in the direction that the arrows on device are pointing.
    • Flip the blue battery lock to eject the battery.
    • Remove the battery from the device.
  2. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Using your Phillips #00 screwdriver, remove all four 0.3 cm screws that are located on both ends, as well as the bottom of your Cyber-Shot.
    • Make sure that your screws are placed on a flat, still surface so they do not roll away.
  3. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Gently pull away the back end of the camera where the LCD screen is located.
    • Remove the metal frame that is located around the LCD screen.
  4. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Remove the front cover.
  5. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Gently remove the lens from the device.
    • The lens will hang on by the orange strips, be careful not to tug on the lens.
  6. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: paso 6, imagen 1 de 2 Sony Cyber-shot DSC-TX55 LCD Screen Replacement: paso 6, imagen 2 de 2
    • Gently slide the LCD screen using very light pressure to the right until it pops open.
  7. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: paso 7, imagen 1 de 1
    • The LCD screen will open to the right.
    • Remove the orange tab from the device.
Conclusión
2 personas más completaron esta guía.
Megan East
Miembro Desde 10/13/15
555 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 2,023
