Saltar al contenido principal
Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement, Front Cover: paso 1, imagen 1 de 3 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement, Front Cover: paso 1, imagen 2 de 3 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement, Front Cover: paso 1, imagen 3 de 3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  2. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: paso 2, imagen 1 de 1
    • Use screwdriver to remove screws.
  3. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: paso 3, imagen 1 de 1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  4. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: paso 4, imagen 1 de 1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  5. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement, Front Sliding Lens Cover: paso 5, imagen 1 de 1
    • The front sliding lens cover.
  6. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: paso 6, imagen 1 de 2 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: paso 6, imagen 2 de 2
    • Remove four screws using Phillips located on the inside of the front cover.
  7. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: paso 7, imagen 1 de 2 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: paso 7, imagen 2 de 2
    • Remove front sliding lens cover.
  8. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: paso 8, imagen 1 de 2 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: paso 8, imagen 2 de 2
    • The front sliding lens cover is now removed and may be repair or replaced.
Conclusión
Una persona más ha completado esta guía.
Stephannie Allen
Miembro Desde 03/11/13
255 Reputación
10 Guías creadas
Equipo
Clemson, Team 13-1, Benson Spring 2013 Miembro de Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 22
Todo El Tiempo: 1,220
