Saltar al contenido principal
Sony Cyber-shot DSC-T9 AV Port Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-T9 AV Port Replacement, Battery: paso 1, imagen 1 de 1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 AV Port Replacement: paso 2, imagen 1 de 1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 AV Port Replacement, Back Cover: paso 3, imagen 1 de 1
    • This is the camera without the front cover.
  4. Sony Cyber-shot DSC-T9 AV Port Replacement: paso 4, imagen 1 de 1
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  5. Sony Cyber-shot DSC-T9 AV Port Replacement: paso 5, imagen 1 de 3 Sony Cyber-shot DSC-T9 AV Port Replacement: paso 5, imagen 2 de 3 Sony Cyber-shot DSC-T9 AV Port Replacement: paso 5, imagen 3 de 3
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  6. Sony Cyber-shot DSC-T9 AV Port Replacement: paso 6, imagen 1 de 3 Sony Cyber-shot DSC-T9 AV Port Replacement: paso 6, imagen 2 de 3 Sony Cyber-shot DSC-T9 AV Port Replacement: paso 6, imagen 3 de 3
    • Pull apart the inner hardware from the back case by prying on the left side.
  7. Sony Cyber-shot DSC-T9 AV Port Replacement: paso 7, imagen 1 de 1
    • Remove the back cover.
  8. Sony Cyber-shot DSC-T9 AV Port Replacement: paso 8, imagen 1 de 1
    • The back cover is now removed from the internal hardware.
  9. Sony Cyber-shot DSC-T9 AV Port Replacement, CCD Module: paso 9, imagen 1 de 1
    • This is the CCD module.
  10. Sony Cyber-shot DSC-T9 AV Port Replacement: paso 10, imagen 1 de 1
    • Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • These are the two ribbons.
  11. Sony Cyber-shot DSC-T9 AV Port Replacement: paso 11, imagen 1 de 1
    • Remove CCD module.
    • You may have to tug on the ribbons to remove the CCD module.
  12. Sony Cyber-shot DSC-T9 AV Port Replacement: paso 12, imagen 1 de 1
    • The CCD module is now removed from the camera.
  13. Sony Cyber-shot DSC-T9 AV Port Replacement, AV Port: paso 13, imagen 1 de 2 Sony Cyber-shot DSC-T9 AV Port Replacement, AV Port: paso 13, imagen 2 de 2
    • These two screws hold in the AV port.
    • Use Phillips screwdriver to remove screws.
  14. Sony Cyber-shot DSC-T9 AV Port Replacement: paso 14, imagen 1 de 1
    • Remove metal screw plate.
  15. Sony Cyber-shot DSC-T9 AV Port Replacement: paso 15, imagen 1 de 1
    • Use pry stick to pop off ribbon.
  16. Sony Cyber-shot DSC-T9 AV Port Replacement: paso 16, imagen 1 de 1
    • Remove AV port from camera.
Conclusión
Stephannie Allen
Miembro Desde 03/11/13
255 Reputación
10 Guías creadas
Equipo
Clemson, Team 13-1, Benson Spring 2013 Miembro de Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 607
