Introducción
By following 4 easy steps, you will be able to open the camera, locate the tripod receptacle, and replace it.
Qué necesitas
Remove all seven black 4 mm Philips #00 screws holding the front panel into place. Two on each of the sides of the camera and three on the bottom.
Remove the one sliver 4mm Philips #00 screw that is holding the receptacle in place near the bottom of the camera.
Casi Terminas!
Conclusión
