Introducción
This guide gives step-by-step instructions on getting to the main internal component of the Cyber-shot DSC-T1 and then specifies how to detach them from the camera.
Qué necesitas
Locate the battery door at the bottom of the camera.
Press down on the door and slide it back. The door will pop open.
Use a PH00 screwdriver and remove the six 2.9mm screws.
Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
The second picture shows what these tabs look like in their open positions.
Carefully disengage the internal components from the casing by lifting at the bottom end and giving a gentle tug.
The components are still connected to the casing via cables, but they are much more maneuverable.
The flash module is shown on the right hand side.
Use tweezers to slide the white piece on the back of the back cover to the right.
This will dislodge the white piece, allowing you to remove it from the back cover.
