Introducción
This guide will aid you in the process of replacing the battery.
Locate the cover on the bottom of the camera.
  • Locate the cover on the bottom of the camera.
  • Slide the cover towards the back of the camera.
  • Be careful—the battery can slide out on its own.
Agregar Comentario
Carefully remove the exposed battery.
  • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
Agregar Comentario
Conclusión
Rosario
Miembro Desde 12/04/12
24 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 7-35, Maness Spring 2012 Miembro de Cal Poly, Team 7-35, Maness Spring 2012
CPSU-MANESS-S12S7G35
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 463
