Saltar al contenido principal
Sony Cyber-shot DSC-P9 Outer Casing Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-P9 Outer Casing Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 Outer Casing Replacement: paso 2, imagen 1 de 1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 Outer Casing Replacement: paso 3, imagen 1 de 2 Sony Cyber-shot DSC-P9 Outer Casing Replacement: paso 3, imagen 2 de 2
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 Outer Casing Replacement, Outer Casing: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-P9 Outer Casing Replacement, Outer Casing: paso 4, imagen 2 de 2
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Sony Cyber-shot DSC-P9 Outer Casing Replacement: paso 5, imagen 1 de 2 Sony Cyber-shot DSC-P9 Outer Casing Replacement: paso 5, imagen 2 de 2
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 Outer Casing Replacement: paso 6, imagen 1 de 2 Sony Cyber-shot DSC-P9 Outer Casing Replacement: paso 6, imagen 2 de 2
    • Then, pull the front case away from the rest of the camera.
  7. Sony Cyber-shot DSC-P9 Outer Casing Replacement: paso 7, imagen 1 de 1
    • After the casing is removed, the camera should look as shown.
Conclusión
Una persona más ha completado esta guía.
Jenna Crawford
Miembro Desde 04/09/12
50 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 17-25, Amido Spring 2012 Miembro de Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 765
