Saltar al contenido principal
Sony Cyber-shot DSC-P9 Lens Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-P9 Lens Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 Lens Replacement: paso 2, imagen 1 de 1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 Lens Replacement: paso 3, imagen 1 de 2 Sony Cyber-shot DSC-P9 Lens Replacement: paso 3, imagen 2 de 2
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 Lens Replacement, Outer Casing: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-P9 Lens Replacement, Outer Casing: paso 4, imagen 2 de 2
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Sony Cyber-shot DSC-P9 Lens Replacement: paso 5, imagen 1 de 2 Sony Cyber-shot DSC-P9 Lens Replacement: paso 5, imagen 2 de 2
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 Lens Replacement: paso 6, imagen 1 de 2 Sony Cyber-shot DSC-P9 Lens Replacement: paso 6, imagen 2 de 2
    • Then, pull the front case away from the rest of the camera.
  7. Sony Cyber-shot DSC-P9 Lens Replacement: paso 7, imagen 1 de 1
    • After the casing is removed, the camera should look as shown.
  8. Sony Cyber-shot DSC-P9 Lens Replacement, Lens: paso 8, imagen 1 de 2 Sony Cyber-shot DSC-P9 Lens Replacement, Lens: paso 8, imagen 2 de 2
    • Dislodge the round casing from the lens.
    • Pull it away from the rest of the camera.
  9. Sony Cyber-shot DSC-P9 Lens Replacement: paso 9, imagen 1 de 1
    • Unscrew the two 4.0mm Phillips #000 screws from the display.
  10. Sony Cyber-shot DSC-P9 Lens Replacement: paso 10, imagen 1 de 1
    • Pull the two ribbon cables out of their slots on the back circuit board.
  11. Sony Cyber-shot DSC-P9 Lens Replacement: paso 11, imagen 1 de 1
    • Remove the three 4.0mm Phillips #000 screws holding the back panel in place.
  12. Sony Cyber-shot DSC-P9 Lens Replacement: paso 12, imagen 1 de 3 Sony Cyber-shot DSC-P9 Lens Replacement: paso 12, imagen 2 de 3 Sony Cyber-shot DSC-P9 Lens Replacement: paso 12, imagen 3 de 3
    • Work the back panel out from under the small grey clip.
    • Slide the back panel off of the camera by dislodging it from the remaining clips.
    • Below is a flat, orange cable connecting the lens to the motherboard.
    • Be careful not to bend the back plate during this process.
  13. Sony Cyber-shot DSC-P9 Lens Replacement: paso 13, imagen 1 de 1
    • Turn the camera over so that you can see the front of the lens.
    • Two connectors link the lens to the motherboard.
    • Gently bring the lens away from the camera.
  14. Sony Cyber-shot DSC-P9 Lens Replacement: paso 14, imagen 1 de 1
    • Using the flat end of the plastic spudger tool, flip up the black tabs on the connectors.
    • Be careful not to exert too much force, as the connectors are delicate.
  15. Sony Cyber-shot DSC-P9 Lens Replacement: paso 15, imagen 1 de 3 Sony Cyber-shot DSC-P9 Lens Replacement: paso 15, imagen 2 de 3 Sony Cyber-shot DSC-P9 Lens Replacement: paso 15, imagen 3 de 3
    • Gently pull out the cables and move the lens away from the rest of the camera.
    • You should now have two distinct, separate components.
Conclusión
Una persona más ha completado esta guía.
Sean Sayles
Miembro Desde 05/09/12
7 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 17-25, Amido Spring 2012 Miembro de Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 16
Todo El Tiempo: 1,362
