Saltar al contenido principal
Sony Cyber-shot DSC-P9 LCD Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-P9 LCD Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 LCD Replacement: paso 2, imagen 1 de 1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 LCD Replacement: paso 3, imagen 1 de 2 Sony Cyber-shot DSC-P9 LCD Replacement: paso 3, imagen 2 de 2
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 LCD Replacement, LCD: paso 4, imagen 1 de 1
    • Unscrew the four 3.0mm Phillips #000 screws holding the back case onto the camera; there are two screws on top and two on the bottom.
  5. Sony Cyber-shot DSC-P9 LCD Replacement: paso 5, imagen 1 de 2 Sony Cyber-shot DSC-P9 LCD Replacement: paso 5, imagen 2 de 2
    • Pull the back case gently away from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 LCD Replacement: paso 6, imagen 1 de 1
    • Remove the two 3.0mm Phillips #000 screws holding the display to the metal backing.
  7. Sony Cyber-shot DSC-P9 LCD Replacement: paso 7, imagen 1 de 2 Sony Cyber-shot DSC-P9 LCD Replacement: paso 7, imagen 2 de 2
    • Unlatch the display by sliding it towards the circuit board.
  8. Sony Cyber-shot DSC-P9 LCD Replacement: paso 8, imagen 1 de 1
    • Remove the two ribbon cables attached to the circuit board by gently pulling them out of their slots.
    • Be careful not to rip the ribbon cables while disconnecting them.
  9. Sony Cyber-shot DSC-P9 LCD Replacement: paso 9, imagen 1 de 1
    • The LCD is now separated from the camera.
Conclusión
Jenna Crawford
Miembro Desde 04/09/12
50 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 17-25, Amido Spring 2012 Miembro de Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 885
