Saltar al contenido principal
Sony Cyber-shot DSC-P100 Camera Lens Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: paso 1, imagen 1 de 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: paso 1, imagen 2 de 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: paso 1, imagen 3 de 3
    • First locate the appropriate screws for detachment.
  2. Sony Cyber-shot DSC-P100 Camera Lens Replacement: paso 2, imagen 1 de 1
    • Remove the five screws shown using a Phillips #00 Screwdriver.
    • It is important to put the small screws in a safe location in order to reassemble the casing.
  3. Sony Cyber-shot DSC-P100 Camera Lens Replacement: paso 3, imagen 1 de 1
    • Using a spudger, carefully pry open the front casing.
  4. Sony Cyber-shot DSC-P100 Camera Lens Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-P100 Camera Lens Replacement: paso 4, imagen 2 de 2
    • Carefully separate the front casing from the camera body.
    • CAUTION: Be careful not to break the wire connecting the front casing and the camera.
  5. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: paso 5, imagen 1 de 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: paso 5, imagen 2 de 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: paso 5, imagen 3 de 3
    • Remove the four screws from the casing.
  6. Sony Cyber-shot DSC-P100 Camera Lens Replacement: paso 6, imagen 1 de 2 Sony Cyber-shot DSC-P100 Camera Lens Replacement: paso 6, imagen 2 de 2
    • Carefully pull the back casing away from the camera.
  7. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Camera Lens: paso 7, imagen 1 de 2 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Camera Lens: paso 7, imagen 2 de 2
    • Remove the two screws on the back side of the camera surrounding the LCD screen.
  8. Sony Cyber-shot DSC-P100 Camera Lens Replacement: paso 8, imagen 1 de 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement: paso 8, imagen 2 de 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement: paso 8, imagen 3 de 3
    • Remove the two ribbon traces found on the left side of the lens on the front of camera holding the lens in place.
    • Carefully pull the lens away front the camera until it is released.
  9. Sony Cyber-shot DSC-P100 Camera Lens Replacement: paso 9, imagen 1 de 1
    • The lens is now successfully removed from the camera.
Conclusión
Una persona más ha completado esta guía.
Katie McCraw
Miembro Desde 03/09/12
191 Reputación
7 Guías creadas
Equipo
Clemson, Team 1-5, Benson Spring 2012 Miembro de Clemson, Team 1-5, Benson Spring 2012
CLEM-BENSON-S12S1G5
4 Miembros
14 Guías creadas
Un comentario
Is there a way to disassemble the lens to correct the alignment. My daughter dropped it and I think the mechanism has been misaligned.
Macjune Tolentino - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 31
Todo El Tiempo: 2,662
