Saltar al contenido principal
Sony Cyber-shot DSC-P100 Camera Flash Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: paso 1, imagen 1 de 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: paso 1, imagen 2 de 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: paso 1, imagen 3 de 3
    • First locate the appropriate screws for detachment.
  2. Sony Cyber-shot DSC-P100 Camera Flash Replacement: paso 2, imagen 1 de 1
    • Remove the five screws shown using a Phillips #00 Screwdriver.
    • It is important to put the small screws in a safe location in order to reassemble the casing.
  3. Sony Cyber-shot DSC-P100 Camera Flash Replacement: paso 3, imagen 1 de 1
    • Using a spudger, carefully pry open the front casing.
  4. Sony Cyber-shot DSC-P100 Camera Flash Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-P100 Camera Flash Replacement: paso 4, imagen 2 de 2
    • Carefully separate the front casing from the camera body.
    • CAUTION: Be careful not to break the wire connecting the front casing and the camera.
  5. Sony Cyber-shot DSC-P100 Camera Flash Replacement, Camera Flash: paso 5, imagen 1 de 2 Sony Cyber-shot DSC-P100 Camera Flash Replacement, Camera Flash: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, gently pull the ribbon trace out of its housing found on the left side of the flash.
  6. Sony Cyber-shot DSC-P100 Camera Flash Replacement: paso 6, imagen 1 de 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement: paso 6, imagen 2 de 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement: paso 6, imagen 3 de 3
    • Using a spudger, pry the small latch between the lens and the flash open to release the flash.
    • Pull the flash away from the camera.
Conclusión
Katie McCraw
Miembro Desde 03/09/12
191 Reputación
7 Guías creadas
Equipo
Clemson, Team 1-5, Benson Spring 2012 Miembro de Clemson, Team 1-5, Benson Spring 2012
CLEM-BENSON-S12S1G5
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 25
Todo El Tiempo: 2,560
