Saltar al contenido principal
Sony Cyber-shot DSC-HX90V Button Board Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: paso 1, imagen 1 de 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: paso 1, imagen 2 de 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: paso 1, imagen 3 de 3
    • Remove the marked screw with a Phillips #000 screwdriver.
    • Remove the marked black M1.4 X 3.5 Phillips head screws
    • Use the spudger to gently remove the lower panel.
  2. Sony Cyber-shot DSC-HX90V Button Board  Replacement: paso 2, imagen 1 de 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: paso 2, imagen 2 de 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: paso 2, imagen 3 de 3
    • After removing the marked black M1.4 X 3.5 Phillips head screws with the Phillips #000 screwdriver on the side panel, using the spudger where the red arrow marks, insert and gently remove the side panel from the device.
    • From either corner of the button board gently use hands to remove the button board.
  3. Sony Cyber-shot DSC-HX90V Button Board  Replacement: paso 3, imagen 1 de 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: paso 3, imagen 2 de 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • After the outer black panel case of button is removed, gently disconnect the control board data cable to the motherboard utilizing the tweezers gently where the red arrow marks.
    • Ribbon wires can easily be damaged.
Conclusión
Marin Rusinov
Miembro Desde 02/02/17
853 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 27
Todo El Tiempo: 2,010
