Saltar al contenido principal
Sony Cyber-shot DSC-HX80 LCD Screen Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-HX80 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 1
    • Before disassembling any part of the camera, turn off the power by pressing down on the ON/OFF button. The ON/OFF button is located on top of the camera.
  2. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Open the compartment located at the bottom of the camera. Slide the LOCK/OPEN switch to the OPEN side. Locate the small blue tab on the side. Pull it in direction away from battery. Remove the battery and set it aside.
  3. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: paso 3, imagen 1 de 2 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: paso 3, imagen 2 de 2
    • Flip LCD screen upwards.
    • Use the PH000 Phillips head screwdriver to remove the two 0.3 mm Phillips black screws located on the sides of the LCD screen. Place screws on magnetic mat or plastic bag.
  4. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: paso 4, imagen 2 de 2
    • Use the PH000 Phillips head screwdriver to remove the two additional 0.3 mm black Phillips screws located on the top edge of the LCD screen. Place screws on magnetic mat or plastic bag.
  5. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: paso 5, imagen 1 de 3 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: paso 5, imagen 2 de 3 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: paso 5, imagen 3 de 3
    • Use a nylon spudger to gently remove the damaged LCD screen off the camera.
    • Replace LCD screen with new one.
Conclusión
4 personas más completaron esta guía.
Gordon Jones
Miembro Desde 10/02/18
1,057 Reputación
5 Guías creadas
Equipo
6 comentarios
You should note that there is a small rectangular magnet (perhaps 8mm long and 2mm across) that has to be placed at the top of the LCD directly under the flash switch. Otherwise the LCD image will be upside down.
Dale Bjerning - Contestar
Hello could you show a picture of where exactly under the flash has to be the magnetite tangle. Thanks.
Wolfina -
Anyone know where I can find the cable from the screen to the camera?
Thorusofer Dragon Knight - Contestar
where can i find the screen other then threw sony
ninjadawn25 - Contestar
Im looking for lcd screen for sony dsc hx80 on back TX08D155HMOAAA. A9N9I523946
Kaz Balcerzak - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 58
Todo El Tiempo: 3,256
