Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Sony Cyber-shot DSC-HX300 View Finder Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-HX300 View Finder Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 View Finder Replacement: paso 2, imagen 1 de 1
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 View Finder Replacement: paso 3, imagen 1 de 1
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 View Finder Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-HX300 View Finder Replacement: paso 4, imagen 2 de 2
    • Remove the battery.
  5. Sony Cyber-shot DSC-HX300 View Finder Replacement, View Finder: paso 5, imagen 1 de 3 Sony Cyber-shot DSC-HX300 View Finder Replacement, View Finder: paso 5, imagen 2 de 3 Sony Cyber-shot DSC-HX300 View Finder Replacement, View Finder: paso 5, imagen 3 de 3
    • Make sure to remove the battery before disassembly to prevent electrocution.
    • Remove the 3 (4 cm) Philips head screws holding the plastic camera housing together. They are located on the back of the camera.
    • Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
    • Turn the camera upside down and remove the remaining 3 (4 cm) Phillips head screws holding the plastic housing together.
  6. Sony Cyber-shot DSC-HX300 View Finder Replacement: paso 6, imagen 1 de 2 Sony Cyber-shot DSC-HX300 View Finder Replacement: paso 6, imagen 2 de 2
    • Using a plastic opening tool, separate the plastic camera housing.
  7. Sony Cyber-shot DSC-HX300 View Finder Replacement: paso 7, imagen 1 de 1
    • Disconnect the ribbon wire attaching the screen to the camera.
  8. Sony Cyber-shot DSC-HX300 View Finder Replacement: paso 8, imagen 1 de 2 Sony Cyber-shot DSC-HX300 View Finder Replacement: paso 8, imagen 2 de 2
    • Remove the 1 (2 cm) Phillips head screw
    • Remove the 2 (5 cm) Phillips head screws that mount the View Finder to the camera.
    • Carefully disconnect the ribbon wire that connects the View Finder to the Motherboard.
  9. Sony Cyber-shot DSC-HX300 View Finder Replacement: paso 9, imagen 1 de 2 Sony Cyber-shot DSC-HX300 View Finder Replacement: paso 9, imagen 2 de 2
    • Gently pull the plastic View Finder off of the metal mounting bracket.
  10. Sony Cyber-shot DSC-HX300 View Finder Replacement: paso 10, imagen 1 de 1
    • The replacement View Finder can now be installed.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 4-6, Meier Fall 2015 Miembro de USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
Miembros de 4
18 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 1,522
