Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Sony Cyber-shot DSC-HX300 Motherboard Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-HX300 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
    Pregunta a FixBot
    Agregar Comentario
  2. Sony Cyber-shot DSC-HX300 Motherboard Replacement: paso 2, imagen 1 de 1
    • Push battery cover away from the camera.
    Pregunta a FixBot
    Agregar Comentario
  3. Sony Cyber-shot DSC-HX300 Motherboard Replacement: paso 3, imagen 1 de 1
    • Push the blue tab that secures the battery. The battery will then spring out.
    Pregunta a FixBot
    Agregar Comentario
  4. Sony Cyber-shot DSC-HX300 Motherboard Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-HX300 Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the battery.
    Pregunta a FixBot
    Agregar Comentario
  5. Sony Cyber-shot DSC-HX300 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 3 Sony Cyber-shot DSC-HX300 Motherboard Replacement, Motherboard: paso 5, imagen 2 de 3 Sony Cyber-shot DSC-HX300 Motherboard Replacement, Motherboard: paso 5, imagen 3 de 3
    • Make sure to remove the battery before disassembly to prevent electrocution.
    • Remove the 3 (4 cm) Phillips head screws located on the back of the camera.
    • Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
    • Turn the camera upside down to remove the remaining the 3 (4 cm) Phillips head screws holding the plastic camera housing together.
    Pregunta a FixBot
    Agregar Comentario
  6. Sony Cyber-shot DSC-HX300 Motherboard Replacement: paso 6, imagen 1 de 2 Sony Cyber-shot DSC-HX300 Motherboard Replacement: paso 6, imagen 2 de 2
    • Using a plastic opening tool, separate the plastic camera housing.
    Pregunta a FixBot
    Agregar Comentario
  7. Sony Cyber-shot DSC-HX300 Motherboard Replacement: paso 7, imagen 1 de 1
    • Disconnect the ribbon wire attaching the screen to the camera.
    Pregunta a FixBot
    Agregar Comentario
  8. Sony Cyber-shot DSC-HX300 Motherboard Replacement: paso 8, imagen 1 de 3 Sony Cyber-shot DSC-HX300 Motherboard Replacement: paso 8, imagen 2 de 3 Sony Cyber-shot DSC-HX300 Motherboard Replacement: paso 8, imagen 3 de 3
    • Carefully remove the 7 ribbon wires connected to the mother board.
    • Remove the 2 (5 cm) Phillips head screws on the speaker mounting bracket.
    • Remove the 3 (4 cm) Phillips head screws that secure the motherboard to the camera.
    • Lift up on the speaker mounting bracket to remove it.
    Pregunta a FixBot
    Agregar Comentario
  9. Sony Cyber-shot DSC-HX300 Motherboard Replacement: paso 9, imagen 1 de 2 Sony Cyber-shot DSC-HX300 Motherboard Replacement: paso 9, imagen 2 de 2
    • Carefully disconnect the ribbon wire connecting the HDMI port to the Motherboard.
    • Once the Motherboard is removed the replacement can be installed.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Equipo
USF Tampa, Team 4-6, Meier Fall 2015 Miembro de USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
Miembros de 4
18 Guías creadas
3Guía Comentarios
During my vacation two capicators on the motherboard failed and 'exploded'.
I've ordered the motherboard and replaced it exactly as described here. Thanks for the explanation!
But since I've replaced it, I have autofocus problems, the camera isn't capable to focus, especially in wide zoom.
Is this something that needs to be calibrated or something?
Erik Mourik - Contestar Compartir
Where can you order a motherboard?
Astrid - Contestar Compartir
That ist what i need to know too. Where can i order a Motherboard?
Jürgen Frömmert - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 19
Ultimos 30 días: 65
Todo El Tiempo: 3,362
