Introducción
If your computer does not register that the Sony Cyber-shot DSC-HX300 is plugged in then the HDMI/USB ports may need to be replaced.
Qué necesitas
Remove the 3 (4 cm) Phillips head screws located on the back of the camera.
Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
Turn the camera upside down to remove the remaining the 3 (4 cm) Phillips head screws holding the plastic camera housing together.
Remove the 3 (4 cm) Phillips head screws securing a mounting bracket over the HDMI/USB Port.
2 personas más completaron esta guía.
