Saltar al contenido principal
Sony Cyber-shot DSC-HX1 LCD Screen Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-HX1 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 1
    • Extend the LCD screen away from the camera to access the screws on the back of its housing.
  2. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Unscrew the three #00 2.0 mm Phillips screws on the back of the casing.
  3. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Place the camera with the lens down.
    • Tilt the screen upwards to see the screw on the bottom of the housing.
    • Unscrew this #00 4.0 mm Phillips screw.
  4. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Pry the casing apart using your plastic opening tool. Begin by prying at the hole where you removed the screw and continue along the seam.
  5. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: paso 5, imagen 1 de 2 Sony Cyber-shot DSC-HX1 LCD Screen Replacement: paso 5, imagen 2 de 2
    • Lift the transparent section of the plastic housing off.
    • Lift the rubber screen bumper off of the screen.
  6. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: paso 6, imagen 1 de 1
    • Pull up on the screen to reveal the data attachment cable.
    • Carefully pull the LCD screen away from enclosure to remove the cable and screen completely.
Conclusión
5 personas más completaron esta guía.
Brianna Greenlaw
Miembro Desde 04/06/15
1,181 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 17-3, Forte Spring 2015 Miembro de Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
4 Miembros
10 Guías creadas
4 comentarios
What is the lcd screen part number? And where can i find it online? I need to replace my dads cracked screen.
sportyvangchick - Contestar
lao90227ay
s300gc05lb9e21xmo usp5280371
lajos rohony - Contestar
Screen LCDOnline booking
prince Choudhary - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 30
Todo El Tiempo: 2,881
