Saltar al contenido principal
Sony Cyber-shot DSC-HX1 Button Assembly Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-HX1 Button Assembly Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
    • Place the camera with the bottom facing you and the lens facing up.
  2. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: paso 2, imagen 1 de 1
    • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
  3. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: paso 3, imagen 1 de 2 Sony Cyber-shot DSC-HX1 Button Assembly Replacement: paso 3, imagen 2 de 2
    • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
    • The battery is not shown here. However, normally the battery would be in the displayed compartment.
  4. Sony Cyber-shot DSC-HX1 Button Assembly Replacement, Button Assembly: paso 4, imagen 1 de 1
    • On the top of the inside the battery compartment, remove the #00 6.0 mm Phillips screw.
  5. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: paso 5, imagen 1 de 2 Sony Cyber-shot DSC-HX1 Button Assembly Replacement: paso 5, imagen 2 de 2
    • Lift the button housing from its position on top of the camera.
Conclusión
Una persona más ha completado esta guía.
Brianna Greenlaw
Miembro Desde 04/06/15
1,151 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 17-3, Forte Spring 2015 Miembro de Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 8
Todo El Tiempo: 793
