Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Sony Cyber-shot DSC-H200 SD Door Replacement
Qué necesitas
    1. Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: paso 1, imagen 1 de 2 Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: paso 1, imagen 2 de 2
      • Using a screwdriver, remove four 6mm screws located on the back panel.
      Pregunta a FixBot
      Agregar Comentario
    2. Sony Cyber-shot DSC-H200 SD Door Replacement: paso 2, imagen 1 de 1
      • Using a screwdriver, remove the two 6mm screws on the bottom.
      • Using a screwdriver, remove the four 3mm screws on the bottom.
      Pregunta a FixBot
      Agregar Comentario
    3. Sony Cyber-shot DSC-H200 SD Door Replacement: paso 3, imagen 1 de 1
      • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
      Pregunta a FixBot
      Agregar Comentario
    4. Sony Cyber-shot DSC-H200 SD Door Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-H200 SD Door Replacement: paso 4, imagen 2 de 2
      • Using the blue plastic opening tools, remove the back panel (the LCD and motherboard are exposed).
      Pregunta a FixBot
      Agregar Comentario
    5. Sony Cyber-shot DSC-H200 SD Door Replacement: paso 5, imagen 1 de 2 Sony Cyber-shot DSC-H200 SD Door Replacement: paso 5, imagen 2 de 2
      • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable).
      • Using the blue plastic opening tool remove the LCD Screen from the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    6. Sony Cyber-shot DSC-H200 SD Door Replacement: paso 6, imagen 1 de 1
      • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
      Pregunta a FixBot
      Agregar Comentario
    7. Sony Cyber-shot DSC-H200 SD Door Replacement: paso 7, imagen 1 de 1
      • Lift the holding plate away from the motherboard and set aside (the pin attaching the door to the body is now accessible).
      Pregunta a FixBot
      Agregar Comentario
    8. Sony Cyber-shot DSC-H200 SD Door Replacement: paso 8, imagen 1 de 2 Sony Cyber-shot DSC-H200 SD Door Replacement: paso 8, imagen 2 de 2
      Herramienta utilizada en este paso:
      • Using tweezers remove the pin that attaches the door to the body.
      Pregunta a FixBot
      Agregar Comentario
    9. Sony Cyber-shot DSC-H200 SD Door Replacement: paso 9, imagen 1 de 1
      • Remove the door.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 45
Todo El Tiempo: 2,134
