Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Sony Cyber-shot DSC-H200 SD Door Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: paso 1, imagen 1 de 2 Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: paso 1, imagen 2 de 2
    • Using a screwdriver, remove four 6mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 SD Door Replacement: paso 2, imagen 1 de 1
    • Using a screwdriver, remove the two 6mm screws on the bottom.
    • Using a screwdriver, remove the four 3mm screws on the bottom.
  3. Sony Cyber-shot DSC-H200 SD Door Replacement: paso 3, imagen 1 de 1
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 SD Door Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-H200 SD Door Replacement: paso 4, imagen 2 de 2
    • Using the blue plastic opening tools, remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 SD Door Replacement: paso 5, imagen 1 de 2 Sony Cyber-shot DSC-H200 SD Door Replacement: paso 5, imagen 2 de 2
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable).
    • Using the blue plastic opening tool remove the LCD Screen from the motherboard.
  6. Sony Cyber-shot DSC-H200 SD Door Replacement: paso 6, imagen 1 de 1
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 SD Door Replacement: paso 7, imagen 1 de 1
    • Lift the holding plate away from the motherboard and set aside (the pin attaching the door to the body is now accessible).
  8. Sony Cyber-shot DSC-H200 SD Door Replacement: paso 8, imagen 1 de 2 Sony Cyber-shot DSC-H200 SD Door Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Using tweezers remove the pin that attaches the door to the body.
  9. Sony Cyber-shot DSC-H200 SD Door Replacement: paso 9, imagen 1 de 1
    • Remove the door.
Conclusión
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 26
Todo El Tiempo: 1,936
