Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Sony Cyber-shot DSC-H200 Motherboard Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-H200 Motherboard Replacement, LCD Screen: paso 1, imagen 1 de 3 Sony Cyber-shot DSC-H200 Motherboard Replacement, LCD Screen: paso 1, imagen 2 de 3 Sony Cyber-shot DSC-H200 Motherboard Replacement, LCD Screen: paso 1, imagen 3 de 3
    • Using a screwdriver, remove the five 6mm screws located on the back panel.
    • Using a screwdriver, remove the two 3mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 Motherboard Replacement: paso 2, imagen 1 de 1
    • Using a screwdriver, remove one 6mm screw on the front panel.
    • Using a screwdriver, remove two 3mm screws on the front panel.
  3. Sony Cyber-shot DSC-H200 Motherboard Replacement: paso 3, imagen 1 de 1
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 Motherboard Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-H200 Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 Motherboard Replacement: paso 5, imagen 1 de 1
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard. (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable.)
  6. Sony Cyber-shot DSC-H200 Motherboard Replacement: paso 6, imagen 1 de 1
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 Motherboard Replacement: paso 7, imagen 1 de 2 Sony Cyber-shot DSC-H200 Motherboard Replacement: paso 7, imagen 2 de 2
    • Lift the holding plate away from the motherboard and set aside.
  8. Sony Cyber-shot DSC-H200 Motherboard Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Using tweezers, open the LCD ribbon port by lifting the black hinge. (The LCD ribbon cable will detach.)
  9. Sony Cyber-shot DSC-H200 Motherboard Replacement: paso 9, imagen 1 de 3 Sony Cyber-shot DSC-H200 Motherboard Replacement: paso 9, imagen 2 de 3 Sony Cyber-shot DSC-H200 Motherboard Replacement: paso 9, imagen 3 de 3
    • Using tweezers, remove the LCD with the ribbon cable and set aside.
  10. Sony Cyber-shot DSC-H200 Motherboard Replacement, Motherboard: paso 10, imagen 1 de 1
    • Disconnect the four amber-colored ribbon cables from the motherboard using tweezers.
  11. Sony Cyber-shot DSC-H200 Motherboard Replacement: paso 11, imagen 1 de 1
    • Disconnect all wires from the motherboard by using a soldering iron.
    • Users unfamiliar with a soldering iron should be extremely careful as the device can get very hot.
  12. Sony Cyber-shot DSC-H200 Motherboard Replacement: paso 12, imagen 1 de 1
    • Gently lift the motherboard away from the camera body.
Conclusión
3 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 28
Todo El Tiempo: 3,333
