Saltar al contenido principal
Sony Cyber-shot DSC-H20 Screen Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-H20 Screen Replacement, Screen: paso 1, imagen 1 de 2 Sony Cyber-shot DSC-H20 Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Screen Replacement: paso 2, imagen 1 de 1
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Screen Replacement: paso 3, imagen 1 de 2 Sony Cyber-shot DSC-H20 Screen Replacement: paso 3, imagen 2 de 2
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Screen Replacement: paso 4, imagen 1 de 3 Sony Cyber-shot DSC-H20 Screen Replacement: paso 4, imagen 2 de 3 Sony Cyber-shot DSC-H20 Screen Replacement: paso 4, imagen 3 de 3
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Screen Replacement: paso 5, imagen 1 de 1
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  6. Sony Cyber-shot DSC-H20 Screen Replacement: paso 6, imagen 1 de 3 Sony Cyber-shot DSC-H20 Screen Replacement: paso 6, imagen 2 de 3 Sony Cyber-shot DSC-H20 Screen Replacement: paso 6, imagen 3 de 3
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Screen Replacement: paso 7, imagen 1 de 1
    • Remove the power shutter unit.
  8. Sony Cyber-shot DSC-H20 Screen Replacement: paso 8, imagen 1 de 2 Sony Cyber-shot DSC-H20 Screen Replacement: paso 8, imagen 2 de 2
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
  9. Sony Cyber-shot DSC-H20 Screen Replacement: paso 9, imagen 1 de 1
    • Remove the two screws from the bottom of the motherboard.
  10. Sony Cyber-shot DSC-H20 Screen Replacement: paso 10, imagen 1 de 1
    • Use the plastic opening tool to assist you in separating the metal frame from the back cover of the camera.
  11. Sony Cyber-shot DSC-H20 Screen Replacement: paso 11, imagen 1 de 2 Sony Cyber-shot DSC-H20 Screen Replacement: paso 11, imagen 2 de 2
    • Flip the metal frame over to the left side of the camera and onto the surface on which you are working.
  12. Sony Cyber-shot DSC-H20 Screen Replacement: paso 12, imagen 1 de 2 Sony Cyber-shot DSC-H20 Screen Replacement: paso 12, imagen 2 de 2
    • Now remove the LCD screen by bringing the back cover over to the left so that the LCD screen falls into your hand.
Conclusión
2 personas más completaron esta guía.
Rachel Payne
Miembro Desde 02/23/15
386 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-1, Leahy Winter 2015 Miembro de USF Tampa, Team 1-1, Leahy Winter 2015
USFT-LEAHY-W15S1G1
3 Miembros
10 Guías creadas
Un comentario
Thank you so much. I could successfully open the camera and got the LCD display out. But I couldn't find out how to replace the LCD, I wanted to mean where to open the LCD cable?
ummejamil - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 1,865
