Saltar al contenido principal
Sony Cyber-shot DSC-H20 Front Cover Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-H20 Front Cover Replacement, Front Cover: paso 1, imagen 1 de 2 Sony Cyber-shot DSC-H20 Front Cover Replacement, Front Cover: paso 1, imagen 2 de 2
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Front Cover Replacement: paso 2, imagen 1 de 1
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Front Cover Replacement: paso 3, imagen 1 de 2 Sony Cyber-shot DSC-H20 Front Cover Replacement: paso 3, imagen 2 de 2
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Front Cover Replacement: paso 4, imagen 1 de 3 Sony Cyber-shot DSC-H20 Front Cover Replacement: paso 4, imagen 2 de 3 Sony Cyber-shot DSC-H20 Front Cover Replacement: paso 4, imagen 3 de 3
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Front Cover Replacement: paso 5, imagen 1 de 2 Sony Cyber-shot DSC-H20 Front Cover Replacement: paso 5, imagen 2 de 2
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  6. Sony Cyber-shot DSC-H20 Front Cover Replacement: paso 6, imagen 1 de 3 Sony Cyber-shot DSC-H20 Front Cover Replacement: paso 6, imagen 2 de 3 Sony Cyber-shot DSC-H20 Front Cover Replacement: paso 6, imagen 3 de 3
    • Pry the front cover of the camera off with the plastic opening tool.
Conclusión
3 personas más completaron esta guía.
Randal Ackett
Miembro Desde 02/23/15
182 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-1, Leahy Winter 2015 Miembro de USF Tampa, Team 1-1, Leahy Winter 2015
USFT-LEAHY-W15S1G1
3 Miembros
10 Guías creadas
Un comentario
I need a new battery port. It has a broken lid and doesn’t keep it closed. Anyone knows where can I get one?
rubens brakarz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 985
