Qué necesitas
Begin by placing the camera flat against a surface and remove the nine (9) black screws. Each screw is of the same length and can be used interchangeably
Place the camera with the lens facing down. Use the phillips head screwdriver to remove the silver screw in the corner near the photo capture button.
Flip the camera over. Use the plastic opening tool to detach the black clip near the capture button.
Grasp the top cover and gently remove it from the camera body.
After the outer casing is removed, lay the device display side up
Gently pry the LCD screen from the body of the camera.
Flip the LCD Assembly around the edge of the camera
Use the plastic opening tool to gently pry up the black tab locking the large ribbon cable to the battery housing.
Grasp the LCD display with your fingers and gently pull the large ribbon cable out of the connector.
The LCD display is now detached from the camera.
