Saltar al contenido principal
Sony Cyber-Shot DSC-W330 LCD Display Replacement
Qué necesitas
  1. Sony Cyber-Shot DSC-W330 LCD Display Replacement, Outer Casing: paso 1, imagen 1 de 3 Sony Cyber-Shot DSC-W330 LCD Display Replacement, Outer Casing: paso 1, imagen 2 de 3 Sony Cyber-Shot DSC-W330 LCD Display Replacement, Outer Casing: paso 1, imagen 3 de 3
    • Begin by placing the camera flat against a surface and remove the nine (9) black screws. Each screw is of the same length and can be used interchangeably
    • Note: There are two (2) screws on each side, and five (5) on the bottom edge.
  2. Sony Cyber-Shot DSC-W330 LCD Display Replacement: paso 2, imagen 1 de 3 Sony Cyber-Shot DSC-W330 LCD Display Replacement: paso 2, imagen 2 de 3 Sony Cyber-Shot DSC-W330 LCD Display Replacement: paso 2, imagen 3 de 3
    • Use a plastic opening tool to carefully pry off the front casing.
    • Be careful to not to force the casing off. Simply move around the entire case separating where needed.
  3. Sony Cyber-Shot DSC-W330 LCD Display Replacement: paso 3, imagen 1 de 3 Sony Cyber-Shot DSC-W330 LCD Display Replacement: paso 3, imagen 2 de 3 Sony Cyber-Shot DSC-W330 LCD Display Replacement: paso 3, imagen 3 de 3
    • Flip the camera over 180 degrees and similarly pry off the rear casing.
  4. Sony Cyber-Shot DSC-W330 LCD Display Replacement: paso 4, imagen 1 de 3 Sony Cyber-Shot DSC-W330 LCD Display Replacement: paso 4, imagen 2 de 3 Sony Cyber-Shot DSC-W330 LCD Display Replacement: paso 4, imagen 3 de 3
    • Once the outer casings have been removed, the silver side trim should come loose from the camera.
    • Place the camera with the lens facing down. Use the plastic opening tool to pry off the side panel with the USB plug.
    • Note: If you wish to remove the top cover, see the LCD Display Replacement to remove the LCD screen before continuing to Step 5
  5. Sony Cyber-Shot DSC-W330 LCD Display Replacement: paso 5, imagen 1 de 3 Sony Cyber-Shot DSC-W330 LCD Display Replacement: paso 5, imagen 2 de 3 Sony Cyber-Shot DSC-W330 LCD Display Replacement: paso 5, imagen 3 de 3
    • Place the camera with the lens facing down. Use the phillips head screwdriver to remove the silver screw in the corner near the photo capture button.
    • Flip the camera over. Use the plastic opening tool to detach the black clip near the capture button.
    • Grasp the top cover and gently remove it from the camera body.
  6. Sony Cyber-Shot DSC-W330 LCD Display Replacement, LCD Display: paso 6, imagen 1 de 3 Sony Cyber-Shot DSC-W330 LCD Display Replacement, LCD Display: paso 6, imagen 2 de 3 Sony Cyber-Shot DSC-W330 LCD Display Replacement, LCD Display: paso 6, imagen 3 de 3
    • After the outer casing is removed, lay the device display side up
    • Gently pry the LCD screen from the body of the camera.
    • Be careful not to damage the ribbon cables, they are still attached to the camera.
  7. Sony Cyber-Shot DSC-W330 LCD Display Replacement: paso 7, imagen 1 de 3 Sony Cyber-Shot DSC-W330 LCD Display Replacement: paso 7, imagen 2 de 3 Sony Cyber-Shot DSC-W330 LCD Display Replacement: paso 7, imagen 3 de 3
    • Flip the LCD Assembly around the edge of the camera
    • Note: Be careful not to rip the assembly from the camera. It is still attached by the ribbon cables!
    • Use the plastic opening tool to gently pry up the black tab locking the large ribbon cable to the battery housing.
    • Grasp the LCD display with your fingers and gently pull the large ribbon cable out of the connector.
    • The LCD display is now detached from the camera.
Conclusión
Hunter Stewart
Miembro Desde 10/18/13
411 Reputación
3 Guías creadas
Equipo
Clemson, Team 13-4, Benson Fall 2013 Miembro de Clemson, Team 13-4, Benson Fall 2013
CLEM-BENSON-F13S13G4
3 Miembros
14 Guías creadas
Un comentario
What LCD screen can i replace it with
Matnor3339 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 18
Ultimos 30 días: 33
Todo El Tiempo: 1,344
