Saltar al contenido principal
Sony Cyber-Shot DSC-W120 Lens Assembly Replacement
Qué necesitas
  1. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement, Lens Assembly: paso 1, imagen 1 de 1
    • Unscrew the screws on the right side of the camera.
  2. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: paso 2, imagen 1 de 2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: paso 2, imagen 2 de 2
    • Using a plastic opening tool, gently lift the side of the silver piece on the right side of the camera until it can be removed.
  3. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: paso 3, imagen 1 de 3 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: paso 3, imagen 2 de 3 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: paso 3, imagen 3 de 3
    • Use a plastic opening tool to separate the front case of the camera, and gently remove it.
  4. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: paso 4, imagen 1 de 1
    • Use a plastic opening tool to remove the silver piece on the left side of the camera.
  5. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: paso 5, imagen 1 de 1
    • Remove the three screws from the bottom of the camera.
  6. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: paso 6, imagen 1 de 2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: paso 6, imagen 2 de 2
    • Carefully remove the back case with a plastic opening tool.
  7. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: paso 7, imagen 1 de 1
    • Unscrew the screw just above the mode dial.
  8. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Lift the display from the rest of the camera and gently separate the connecting tape using tweezers.
  9. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: paso 9, imagen 1 de 2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: paso 9, imagen 2 de 2
    • Separate the tape connecting the lens to the rest of the camera using tweezers.
    • Remove the lens.
  10. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: paso 10, imagen 1 de 2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: paso 10, imagen 2 de 2
    • Insert wisdom here.
  11. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: paso 11, imagen 1 de 1
Conclusión
2 personas más completaron esta guía.
Dana Sanchez
Miembro Desde 10/21/14
69 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 1-5, Leahy Fall 2014 Miembro de USF Tampa, Team 1-5, Leahy Fall 2014
USFT-LEAHY-F14S1G5
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 29
Ultimos 30 días: 55
Todo El Tiempo: 2,097
