Introducción
It's important to ensure the wrist strap of this camera is in working order to help prevent damage from falls onto hard or hazardous surfaces that can harm the device.
Qué necesitas
Using your finger, slide the release catch to unlock the battery/memory card cover.
Using a Phillips #00 screwdriver, remove one black 2 2/5mm screw that is located next to the wrist band loop.
Using a Phillips #00 screwdriver, remove one silver 3mm screw located on the front side of the camera.
Using a Phillips #00 screwdriver, remove one silver 5 2/5mm screw located on the front side of the camera
Using a Phillips #00 screwdriver, remove one black 2 1/2mm screw located on the front side of the camera.
Using a Phillips #00 screwdriver , remove two silver 3mm screws from the side of the device.
2 personas más completaron esta guía.
