Saltar al contenido principal
Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement
Qué necesitas
  1. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Battery: paso 1, imagen 1 de 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Battery: paso 1, imagen 2 de 2
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 2, imagen 1 de 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 2, imagen 2 de 2
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 3, imagen 1 de 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 3, imagen 2 de 2
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 4, imagen 1 de 1
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Outer Shell: paso 5, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove one black 2 2/5mm screw that is located next to the wrist band loop.
  6. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 6, imagen 1 de 1
    • Using the plastic opening tool, separate the edge-casing from the rest of the camera.
  7. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 7, imagen 1 de 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 7, imagen 2 de 2
    • Pull the edge-casing off of the camera.
  8. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 8, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove one silver 3mm screw located on the front side of the camera.
    • Using a Phillips #00 screwdriver, remove one silver 5 2/5mm screw located on the front side of the camera
    • Using a Phillips #00 screwdriver, remove one black 2 1/2mm screw located on the front side of the camera.
  9. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 9, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove one 2 1/2mm screw located near the wrist strap.
  10. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 10, imagen 1 de 1
    • Using a Phillips #00 screwdriver remove one black 2 2/5mm screw near the tripod slot on the bottom of the casing.
  11. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 11, imagen 1 de 1
    • Using a Phillips #00 screwdriver remove the two 2 2/5mm black screws from the side of the camera opposite of the wrist strap
  12. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 12, imagen 1 de 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 12, imagen 2 de 2
    • Using the plastic opening tool, open the device's outer shell.
  13. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 13, imagen 1 de 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 13, imagen 2 de 2
    • Remove the front casing of the device.
  14. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Back Casing: paso 14, imagen 1 de 3 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Back Casing: paso 14, imagen 2 de 3 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Back Casing: paso 14, imagen 3 de 3
    • Using the plastic opening tool, remove the back casing of the device.
  15. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Wrist Strap Holster: paso 15, imagen 1 de 1
    • Using a Phillips #00 screwdriver , remove two silver 3mm screws from the side of the device.
  16. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: paso 16, imagen 1 de 1
    • Using your fingers, remove the silver wrist band holster from the device.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 434
