Introducción
If the movie button gets stuck or comes loose, it must be replaced to ensure that the device works properly and that the device is capable of maintaining an air-tight seal when used underwater to prevent water damage.
Qué necesitas
Using your finger, slide the release catch to unlock the battery/memory card cover.
Using a Phillips #00 screwdriver, remove one black 2 2/5mm screw that is located next to the wrist band loop.
Using a Phillips #00 screwdriver, remove one silver 3mm screw located on the front side of the camera.
Using a Phillips #00 screwdriver, remove one silver 5 2/5mm screw located on the front side of the camera
Using a Phillips #00 screwdriver, remove one black 2 1/2mm screw located on the front side of the camera.
Using the tweezers, remove the movie button from the back casing of the device.
