Saltar al contenido principal
Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement
Qué necesitas
  1. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery: paso 1, imagen 1 de 2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery: paso 1, imagen 2 de 2
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: paso 2, imagen 1 de 2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: paso 2, imagen 2 de 2
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: paso 3, imagen 1 de 2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: paso 3, imagen 2 de 2
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: paso 4, imagen 1 de 1
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery/Memory Card Door Seal: paso 5, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the two 2mm screws on the battery/memory card cover seal.
  6. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: paso 6, imagen 1 de 1
    • Using your fingers, remove the battery/memory card door seal.
Conclusión
3 comentarios
hi sir do you have battery lock for replacement ?
John Anthony Geronez - Contestar
the Cyber shot by Sony has a lousy battery door it breaks very easily it's made of cheap plastic do you have any replacements for it?
SHELIAH HIPPS - Contestar
Where can I get the door catch - is it still available?
sid123 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 1,641
