Saltar al contenido principal
Introducción
In order for the device to work underwater without risk of damage, it must be properly sealed. If the outer shell is damaged or won't properly seal, then its ability to perform underwater without receiving potentially permanent damage is severely reduced.
Partes
No se especificaron partes.
  1. Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Battery: paso 1, imagen 1 de 2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Battery: paso 1, imagen 2 de 2
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: paso 2, imagen 1 de 2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement: paso 2, imagen 2 de 2
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: paso 3, imagen 1 de 2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement: paso 3, imagen 2 de 2
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: paso 4, imagen 1 de 1
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Outer Shell: paso 5, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove one black 2 2/5mm screw that is located next to the wrist band loop.
  6. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: paso 6, imagen 1 de 1
    • Using the plastic opening tool, separate the edge-casing from the rest of the camera.
  7. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: paso 7, imagen 1 de 2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement: paso 7, imagen 2 de 2
    • Pull the edge-casing off of the camera.
  8. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: paso 8, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove one silver 3mm screw located on the front side of the camera.
    • Using a Phillips #00 screwdriver, remove one silver 5 2/5mm screw located on the front side of the camera
    • Using a Phillips #00 screwdriver, remove one black 2 1/2mm screw located on the front side of the camera.
  9. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: paso 9, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove one 2 1/2mm screw located near the wrist strap.
  10. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: paso 10, imagen 1 de 1
    • Using a Phillips #00 screwdriver remove one black 2 2/5mm screw near the tripod slot on the bottom of the casing.
  11. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: paso 11, imagen 1 de 1
    • Using a Phillips #00 screwdriver remove the two 2 2/5mm black screws from the side of the camera opposite of the wrist strap
  12. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: paso 12, imagen 1 de 2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement: paso 12, imagen 2 de 2
    • Using the plastic opening tool, open the device's outer shell.
  13. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: paso 13, imagen 1 de 2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement: paso 13, imagen 2 de 2
    • Remove the front casing of the device.
  14. Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Back Casing: paso 14, imagen 1 de 3 Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Back Casing: paso 14, imagen 2 de 3 Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Back Casing: paso 14, imagen 3 de 3
    • Using the plastic opening tool, remove the back casing of the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 721
