Saltar al contenido principal
Sony Cyber-Shot DSC-S90 Top/Side Case Replacement
Qué necesitas
  1. Sony Cyber-Shot DSC-S90 Top/Side Case Replacement, Batteries: paso 1, imagen 1 de 2 Sony Cyber-Shot DSC-S90 Top/Side Case Replacement, Batteries: paso 1, imagen 2 de 2
    • Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
    • While holding the button downwards, slide the door upwards to unlock and open the door.
  2. Sony Cyber-Shot DSC-S90 Top/Side Case Replacement: paso 2, imagen 1 de 1
    • Pull open the door and allow the batteries to fall out.
  3. Sony Cyber-Shot DSC-S90 Top/Side Case Replacement, Back Case: paso 3, imagen 1 de 2 Sony Cyber-Shot DSC-S90 Top/Side Case Replacement, Back Case: paso 3, imagen 2 de 2
    • Remove the 2mm Phillips #00 screw under the battery port door.
    • Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
  4. Sony Cyber-Shot DSC-S90 Top/Side Case Replacement: paso 4, imagen 1 de 2 Sony Cyber-Shot DSC-S90 Top/Side Case Replacement: paso 4, imagen 2 de 2
    • Remove the two 2mm Phillips #00 screws (one on each side of the camera).
  5. Sony Cyber-Shot DSC-S90 Top/Side Case Replacement: paso 5, imagen 1 de 2 Sony Cyber-Shot DSC-S90 Top/Side Case Replacement: paso 5, imagen 2 de 2
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the right side and bottom of the camera with the LCD screen facing you.
  6. Sony Cyber-Shot DSC-S90 Top/Side Case Replacement: paso 6, imagen 1 de 1
    • Pull apart the back case from the main body of the camera.
  7. Sony Cyber-Shot DSC-S90 Top/Side Case Replacement, Front Case: paso 7, imagen 1 de 1
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the top of the camera.
  8. Sony Cyber-Shot DSC-S90 Top/Side Case Replacement: paso 8, imagen 1 de 1
    • Pull apart the front case from the main body of the camera.
  9. Sony Cyber-Shot DSC-S90 Top/Side Case Replacement, Top/Side Case: paso 9, imagen 1 de 3 Sony Cyber-Shot DSC-S90 Top/Side Case Replacement, Top/Side Case: paso 9, imagen 2 de 3 Sony Cyber-Shot DSC-S90 Top/Side Case Replacement, Top/Side Case: paso 9, imagen 3 de 3
    • Release all clips and latches keeping the casing in place using a spudger, opening tool, or screwdriver.
  10. Sony Cyber-Shot DSC-S90 Top/Side Case Replacement: paso 10, imagen 1 de 1
    • Now the casing can be removed after all latches have been undone.
Conclusión
Jonathan Arns
Miembro Desde 10/28/19
745 Reputación
8 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 83
